monitor ports on 2 switches with 1 port analyzer
Mar 27th, 2009
I've got 2 servers, connected to 2 Cat 6509 individually. I want to monitor both ports with 1 port analyzer (WireShark). if I connect WireShark to one of the switches, and configure 1 SPAN + 1 RSPAN, I can't assign 1 destination port for 2 SPAN/RSPAN sessions. Should I introduce the third switch, and connect WireShark on it?
Mohamad Qayoom Fri, 03/27/2009 - 13:12
  • Bronze, 100 points or more
Are these servers in the same VLAN? If so, did you try to monitor the VLAN they are in?
Mohamad
xiaoliangyue Fri, 03/27/2009 - 13:17
no, in different vlan. Even if they are in same vlan, since they are connected to different switches, Monitoring the Vlan still doesn't work, I think.
