I guess I can answer my own post for the benefit of others. I was able to accomplish what I need by tricking the system using the paging-dn. Once I open the Meet-me conference I forwarded the call to the paging-dn.
ephone-dn 60
number 1160
description Multicast Conference Bridge
paging ip 239.1.1.60 port 2000
Then I fire up trusty VLC from the command line.
C:\Program Files\VideoLAN\VLC>
vlc rtp://@239.1.1.60:2000
(I am planning on using batch file for this so that the user can't make any mistake.)
By issuing this command it sends an IGMP message to the switch which informs the switch that the switchport needs a copy of the multicast packets.
And that is all it takes. You just have to make sure that you have an IP phone that belongs to the paging-dn and it is in idle state. My test shows that it won't work if it is not the case but hey may be it will work on your system.
It is funny how I look at every trick that I can think of looking for an answer while the answer has been sitting in front of me all along. I love my job.
Totie
