Moving MPE Server
Mar 27th, 2009
Customer has a MPE 2.x installation with two servers. They need to readdress the server that is in the DMZ.
Are we going to be just better off rebuilding the DMZ sserver with the new address or might it be as simple as
1) breaking the sma relationship
2) changing the address on the DMZ server
3) changing DNS to reflect the new address
4) re-establishing the sma relationship
Thanks.
aramos17428 Fri, 04/24/2009 - 10:25
Never done the SMA, but I have change IPs and hostnames in MPE (single server) without any issue. I have update DNS to reflect the updates and all worked fine.
However, in our case you may need to re-apply the license and perform a reboot of both MPEs.
