How to Rx default originate only - BGP
Mar 27th, 2009
We have eBGp with our SP and they are sending default to us. When we do a show ip bgp ne X.X.X.X received-routes the O/P says % Inbound soft reconfiguration not enabled on X.X.X.X.
If I do a Soft reconfiguration on the Inbound. It learns a whole lot of routes along with default even if i have a distribute list for the neighbor with deny any which looks like
neighbor X.X.X.X distribute-list 2 in
access-list 2 deny any
Please let me know
1. How do i get only the default.
2. What all events will trigger our SP's Border Gateway to stop sending the default.
Thanks in advance,
Overall Rating: 4 (3 ratings)
subra4u Fri, 03/27/2009 - 15:22
THanks for the info.
I get the following from the sh ip bgp neighbor
Network Next Hop Metric LocPrf Weight Path
r> X.X.X.X 0 65535 i
What could be wrong now?
r -> rib failure.
I am running cat 4500. below is the show ver:
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICESK9-M), Version 12.2(46)SG, RELEASE SOFTWARE (fc1)
Technical Support:
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 27-Jun-08 16:24 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x11E3C0D8
ROM: 12.2(31r)SGA1
Pod Revision 14, Force Revision 31, Tie Revision 32
Telecity_Border_1 uptime is 9 weeks, 4 days, 9 hours, 53 minutes
System image file is "bootflash:cat4500-entservicesk9-mz.122-46.SG.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C4506 (MPC8540) processor (revision 13) with 524288K bytes of memory.
Processor board ID FOX06460YN3
MPC8540 CPU at 800Mhz, Supervisor V-10GE
Last reset from PowerUp
1 Virtual Ethernet interface
58 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x101
Thanks in advance
subra4u Fri, 03/27/2009 - 15:30
I got it. it was due to a lower AD static route already installed. after removing it. I got it working.
Thanks hritter for your help.
Can some one help me with my second doubt.
Edison Ortiz Fri, 03/27/2009 - 15:47
When the BGP router no longer has the on its routing table.
subra4u Fri, 03/27/2009 - 16:35
Thanks for your time.
Does it mean that my SP BG Router has a Default originate from its upstream as well.
Edison Ortiz Fri, 03/27/2009 - 16:39
Does it mean that my SP has a Default originate from its upstream as well.
Hard to tell what the SP may have but there are several ways on how to inject a into BGP or advertise the to a neighbor for that matter.
The SP may have a dynamic or static default route along with the network under BGP.
The SP may also have a dynamic or static default route along with a distribution information originate under BGP.
The SP may have an unconditional default originate on the neighbor statement pointing towards you.
On the latter approach, they don't need to have the in the routing table.
It will advertise the all the time.
subra4u Fri, 03/27/2009 - 16:48
Thanks again.
I would like to know, if for some reason my SP's BGP peering fails with any other T1 SP or fails to learn the routes from its upstream will it be still sending me a default originate (in case of unconditionally sending default originate). What should i do to overcome this. Please help me clear this doubt.
Edison Ortiz Fri, 03/27/2009 - 18:42
The best way to know is asking the provider. Each provider will have different BGP policies on how they handle the network advertisement to customers.
If you still want to send your traffic towards the ISP even if they don't send network, then you can configure a floating default route towards that same ISP. However, if they aren't sending the - you may as well drop it locally.
