Port Security problem
Mar 27th, 2009
have port security configured with the following config on my 6513 running 122-33.SXH3a.
switchport
switchport access vlan 101
switchport mode access
switchport voice vlan 102
switchport port-security
switchport port-security aging time 2
switchport port-security violation restrict
speed 100
duplex full
spanning-tree portfast
When I plug in a phone I start to see tons of errors like this
devicename 18395: Mar 27 15:38:55.661: %PORT_SECURITY-SPSTBY-2-PSECURE_VIOLATION: Security violation occurred, caused by MAC address 0021.7059.6a82 on port GigabitEthernet2/36
This is the mac address of the pc which is connected to the phone but I don't understand why switch will report as a violation, I have tried using a different phone with the same error. Can someone point me what I could be doing wrong?
Thanks.
Overall Rating: 5 (1 ratings)
thotsaphon Fri, 03/27/2009 - 13:23
  • Gold, 750 points or more
Nawaz,
Did you connect PC at the ip phone as well?
Toshi
nawas Fri, 03/27/2009 - 13:26
Yes and I also added
and still seeing errors.
Jon Marshall Fri, 03/27/2009 - 13:25
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Nawaz
The PC will have a mac-address and so will the phone so you need to add to your port config
switchport port-security maximum 2
Jon
thotsaphon Fri, 03/27/2009 - 13:28
Jon,
How did you response so fast?
5P!
Toshi
Jon Marshall Fri, 03/27/2009 - 13:32
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Toshi
Not as fast as you though :-)
Jon
nawas Fri, 03/27/2009 - 13:29
John
It was typo in my previous message, I actually added
and I still see error
thotsaphon Fri, 03/27/2009 - 13:31
Nawaz,
Where is that MAC-Address comming from?
What about these command?
Try this first:
switchport port-security maximum 1 vlan access
switchport port-security maximum 1 vlan voice
Later:
switchport port-security maximum 2 vlan access
Toshi
Jon Marshall Fri, 03/27/2009 - 13:31
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Nawaz
Okay. Looking through some previous posts there seems to be some debate about whether you need to make the number 2 or 3. Could you try -
switchport port-security maximum 3
and see if that makes any difference.
Jon
nawas Fri, 03/27/2009 - 13:41
I only have one voice and one data vlan in this switch so I don't think increasing max vlan will help. I changed the following line from restric to protect and the error went away but I really to use restrict if i can.
Edison Ortiz Fri, 03/27/2009 - 15:44
  • Hall of Fame,
    Founding Member
When using an IP Phone, you need to change your port-security to 3 as the IP Phone during its initial boot-up will be on the data Vlan (consuming a mac-address on that vlan). It will reboot again on the voice vlan hence you need:
2 data
1 voice
HTH,
__
Edison.
