WLC vs Airwave AWMS versions
Mar 27th, 2009
We are evaluating Airwave AWMS. One question is for the compatible version with WLC. Because Cisco always suggest WCS to be equal or higher version than WLC. Then how does this apply to AWMS? For folks using AWMS to manage WLCs, how do you choose AWMS versions? When you upgrade WLCs, do you have to consider the AWMS version as well as we do for WCS?
Trending Topics - Security & Network
