CallManager 4.1 installing device load ATA 3.2(4)
Mar 27th, 2009
Under CallManager 4x downloads the latest/current ciscocm.4-1-DevPack-78.exe still has ATAs using ATA030203SCCP051201A which has a 4K buffer bug and need to upgrade to 3.2(4)
I had to download ata_03_02_04_sccp_090202_a.zip for which the release notes say the installation instructions are in cmterm-ata-sccp.3-2-4-Readme.html, this html file isn't in the .zip file. How/what do I install on the pub/tftp server in this zip file to change the ATA System Device Defaults configuration?
Contents of ata_03_02_03_sccp_051201_a.zip:
1) This file (ata_03_02_03_sccp_051201_a_contents.txt)
2) URL for ATA 188 Release Notes (release_notes.txt)
3) ATA 188 Administrator's Guide URL (admin_guide_url.txt)
4) ATA 188 software image (for PC-based and TFTP methods)
(ATA030203SCCP051201A.zup)
5) Executable upgrade program for PC, Linux, and Sun systems
(sata186us.exe, sata186us.linux, sata186us.sun)
6) Upgrade program instructions (sata186us.txt)
7) Executable debug program for PC, Linux, and Sun systems
(prserv.exe, prserv.linux, prserv.sun)
8) Debug program instructions (prserv.txt)
9) Image name extraction program (zupinfo.exe)
10) Image name extraction program instructions (zupinfo.txt)
11) Executable Windows file for use in creating provisioning
files for PC, Linux, and Sun systems
(cfgfmt.exe, cfgfmt.linux, cfgfmt.sun)
12) Provisioning file maker instructions (cfgfmt.txt)
13) Auxiliary file for use with cfgfmt (ptag.dat)
14) Example SCCP user profile (sccp_example.txt)
15) Configuration tool for the ATA (bitaid.exe)
16) Instructions for using the bitaid tool (bitaid.txt)
17) Tool to allow ATA configuration from command-line prompt (atapost.pl)
18) Atapost program instructions (atapost.txt)
19) Sample web pages showing factory settings for SCCP environments
(SCCPCfg.htm, NetCfg.htm, ToneCfg.htm,
AudioCfg.htm, ServiceCfg.htm, DebugCfg.htm)
20) Configuration information for call progress tones by country
(cptones.txt)
20) Special transition software image for upgrade from v1.xx
(transition.zup)
22) Important upgrade notice for users of software versions
v1.34 or lower (UPGRADE_NOTICE.txt)
