virtual templete in FR
Mar 28th, 2009
Hi, I have configured Virtual-Templete over PPP on Frame Relay connectivity. THe problem is, whenever I am configuring EIGRP or OSPF. Then Neighbor is established, but it is not advertising the Routes/Network......
Giuseppe Larosa Sat, 03/28/2009 - 10:06
Hello Rupesh,
check the ospf network type on both sides
using
sh ip ospf int multilink XX
a network type mismatch can cause this problem.
the command ip ospf network can be used in interface configuration mode to fix this.
Hope to help
Giuseppe
Rupesh Kashyap Mon, 03/30/2009 - 23:06
I have disabled the Split horizon. This problem is with all the protocols. Please help. This is only happening with
