Configuring MTU size
Mar 28th, 2009
Hi ,
I have a requirement to configure mtu size in cisco 6513 series core switch on SVI interface. I would like to know the impact to the other SVI interfaces and in general whether is it best practice to configure mtu on SVI interface or leave it to the physical interface?.
lamav Sat, 03/28/2009 - 07:41
You can configure MTU on both the physical interfaces as well as the SVI for a vlan. The thing is that the MTU of a packet originating on a host on a vlan is not checked at the ingress point to the vlan interface. It is checked, however, upon egress to the vlan. Therefore, if a packet requires L3 switching (which is why it was forwarded to the SVI in the first place, right?), the packet will be fragmented if the MTU is smaller than the MTU of the physical port. Unless, of course, the DF bit is set. With fragmentation comes poor performance, latency, overhead, and applications that can time out and reset.
As an example, if you enable jumbo frames on a physical port that belongs to a certain vlan, it is not enough if you expect that functionality to be extended to the L3 switching domain. You must configure jumbo frame support on the SVI also.
