No port status on C2960 after upgrade from 12.2(46) to 12.2(50)
Mar 28th, 2009
After upgrading a test swicth C2960-48TC-L from 12.2(46)SE to 12.2(50)SE I do have no port status anymore in the CISCO Network Assistent. All port are marked blue.
Here are the slices of my running config:
version 12.2
no service pad
service timestamps debug uptime
service timestamps log datetime
service password-encryption
service sequence-numbers
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa authorization network default local
aaa session-id common
crypto pki trustpoint HTTPS_SS_CERT_KEYPAIR
enrollment selfsigned
serial-number
revocation-check none
rsakeypair HTTPS_SS_CERT_KEYPAIR
crypto pki certificate chain HTTPS_SS_CERT_KEYPAIR
certificate self-signed 01
ip default-gateway uuu.vvv.www.xxx
ip http server
ip http authentication local
ip http secure-server
control-plane
line con 0
line vty 0 4
password 7 xxxxxxxxxxxxxxxxxxxx
length 0
transport input ssh
line vty 5 15
transport input ssh
cisco.net Sat, 03/28/2009 - 11:03
Do you have any special or extra feature requirement which Old IoS was not suporting and you decided for IoS upgradation.
Simply, asking for better understanding.
Jimmy
roland-mueller Sun, 03/29/2009 - 04:24
The only reason for planning the upgrade is the security issues that are solved in 12.2(50)SE.
Roland
roland-mueller Wed, 04/22/2009 - 08:20
No, I was forced by some security issues which are solved in IOS 12.2(50).
Roland
toon_van_hoof Wed, 04/22/2009 - 06:04
Did you already find a solution for this phenomenon? We have the same problem on multiple switches 2960, 3750 but for some reason not on the 3560
roland-mueller Wed, 04/22/2009 - 08:17
Pity wise not. I do have this incident only on the 2960 and NOT on my 3750.
Mayby I spend some hours by playing around with the aaa-new-model & the ip http authentication config in my testlab.
michaelaross Mon, 04/27/2009 - 13:56
I'm having the same problem. All ports on the switches are blue except for our 3750s. I upgraded from 122(25)SEE3/4 to 122(50)SE. Did you end up finding a fix for this issue?
