Call transfer destination based on external document variable
Mar 29th, 2009
Hi all
i need to create a script to transfer call to a specified phone number during out fo business hours.
The phone number have to be inserted day by day, on a simple web page by the contact center personell.
Some suggestion?
Jonathan Schulenberg Sat, 04/11/2009 - 11:25
  • Cisco Designated VIP,
    2017 IP Telephony
Assuming you are using UCCX or IPIVR and not UCCE or CVP: You can use the HTTP steps if you are on Premium licensing to retrieve an XML document from another server. That server can provide any interface you want as long as it saves it into a properly formatted XML document for CCX to retrieve.
You could use an XML file in the document repository if you are on Standard or Enhanced but this requires you to give the contact center personnel admin role on CCX Administration and they must upload the XML file directly.
The script can use xPath to parse the XML file and get the data it needs into a variable it can act upon.
Oh, if you have Premium licensing you could do an ODBC connection to a supported SQL database to get this information as well.
Jonathan Schulenberg Sat, 05/09/2009 - 11:35
    2017 IP Telephony
That's not a proper XML document. This is documented with examples in the CCX documentation.
Scripting and Development Series: Volume 2, Editor Step Reference for Cisco Unified CCX and Cisco Unified IP IVR, Release 7.0(1): http://cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_7_0/user/guide/uccx701edstepref.pdf
