Giuseppe Larosa Sun, 03/29/2009 - 05:28
  • Hall of Fame,
    Founding Member
Hello Ratna,
I don't remember the exact meaning but it should stand for real time switching bus.
To be noted first generation of C7200 had only two standard PCI buses
you can check the chassis type with
sh c7200
you cannot install npe 400 or better in a c7206 non vxr chassis.
Actually we had one installed by error the system was instable with frequent crashes caused by errors in accessing the I/O bus
all modern processors require the VXR version of the chassis
see table 3
http://www.cisco.com/en/US/prod/collateral/routers/ps341/prod_end-of-life_notice09186a008032d592.html
Hope to help
Giuseppe
Sushil Kumar Katre Sun, 03/29/2009 - 22:56
  • Gold, 750 points or more
I agree with Giuseppe. As far as the abbreviation is concerned even I was interested to know that does VXR stands for. I did a search on google and few people suggest that it's "Voice Exchange Router"
-> Sushil
