Help with HSRP lab
Mar 29th, 2009
I would like to configure HSRP with 2 routers and a switch I have. The routers are 2620's which only have one ethernet port, can I practice HSRP with these at all, not sure if I can use a loopback or not?
mahmoodmkl Sun, 03/29/2009 - 13:13
  • Gold, 750 points or more
yeh u can configure HSRP with the above devices..
Why u want to use loopback IP's...?
Yes u can configure loopback interfaces.
Mahmood
lamav Sun, 03/29/2009 - 14:03
  • Blue, 1500 points or more
Hi:
You can configure HSRP with what you have. You dont need loopback interfaces.
R1
interface GigabitEthernet0/1
ip address 138.69.164.251 255.255.252.0
standby 20 ip 138.69.164.250
standby 20 timers 3 6
standby 20 preempt
standby 20 priority 105
R2
ip address 138.69.164.252 255.255.252.0
standby 20 preempt
Victor
whiteford Tue, 03/31/2009 - 13:42
Thanks, this worked.
The router with "standby 20 priority 105" is this the main router as it always takes the active role when both routers are on?
