3750 stack swap out 24 port to 48 port
Mar 29th, 2009
I need to swap out a 24 port 3750 in the centre of a stack and upgrade to a 48 port unit.
If I set the correct switch number and ensure that the IOS is the same as the existing, will the stack just add in the additional 24 ports as unconfigured?
Tony
Leo Laohoo Mon, 03/30/2009 - 02:51
Do a "sh running-config" and in the first 10 or 12 lines or so, you'll see something like "switch X provisioning WS-C3750G-24PS" (if your switch is a C3750G-24PS). Edit this to the model of your switch you want to put in, for example, WS-C3750G-48PS, and even before you put your switch in, you'll see that you can now provision this in your config.
Does this help you?
