ICM Side A & Side B issue
Mar 30th, 2009
We have ICM 7.0 with Side A and Side B.Now system Hard Disk Space is showing very low.Even HDS database is also showing 90%.We are planning to add one more HDD.Can anyone help us how we can proceed further.
happy_248578 Mon, 03/30/2009 - 09:09
Correct Automatic Data Purging is also happening but problem is our ICM SIDE A(Active Server) Disk are running with short of space.Even we changed the DB path also now that is also full.We checked with Cisco also they suggested to upgrade the HDD.........
happy_248578 Mon, 03/30/2009 - 21:06
Currently 80 GB Hard Disk is running which we created two partition C & D.First Logger was pointed to C when C drive space full after that we pointed to D drive. Now D drive is also running with Short of Space.
So now we are planning to add one more Hard Disk but we are not aware we need to move all DB or only we can point Logger to new HDD?
joesnyde Tue, 03/31/2009 - 08:39
You also mention that the HDS is auto purging due to capacity at 90%. Do you have plans to increase the HDS data files to correct this issue? What drive is the HDS data and log files currently on, C:, D:, etc... Eventually you will have degradation when running Webview reports if this is not corrected.
What are the settings of table retention on both the loggers and the HDS? Open ICMDBA (both logger and HDS) drill down to the database _hds right click and then click "estimate" this will show the retention settings for all tables in HDS. You can check for the same at the _sideA database.
