CUCM 6.1(3) MOH on OffNet Call
Answered Question
Mar 30th, 2009
Hi Experts,
I converted mp3 file to :
1. WAV file PCM 16 bit Mono
2. WAV file PCM 16 bit Stereo
before I converted and uploaded the WAV PCM 16 bit Stereo file, I tested WAV PCM 16 bit Mono MOH on on-net call and it is working fine but it doesn't work on offnet called/calling party but when I used the samplemoh both on-net and offnet called/calling party that was on hold could hear the MOH. All site using G711. the WAV PCM 16 bit Stereo file also having same issue
Please advise.
Husien
Correct Answer by Jaime Valencia about 8 years 3 months ago
if you go to the MOH audio source does it says the file was changed successfully to be uses as MOH?
java
if this helps, please rate
Overall Rating: 3 (1 ratings)
Correct Answer
Jaime Valencia Mon, 03/30/2009 - 07:54
  • Cisco Employee,
  • Hall of Fame,
    2011
java
husienlee Mon, 04/06/2009 - 20:03
Yes it was converted as a MOH source successfully. Thanks for the info. the Offnet MOH had been resolved by uploading the wav file to both PUB & SUB.
Husien
