CME Direct Access to GDM
Mar 30th, 2009
Greetings, is it possible to directly access a GDM by dialing it's associated number from a handset rather than going through either a subscriber mailbox or when forwarded calls from the AA?
I had added a dial-peer for its extension but get a fast busy signal, this also happens when trying to forward calls onto the GDM from certain hunt groups.
exonetinf1nity Tue, 03/31/2009 - 01:52
Thank you for your reply, it's CUE, managed to get arround it by bouncing calls of a secondary DN.
