ACE: Single SSL Cert for two domains with same VIP
Answered Question
Mar 30th, 2009
At present I have a design that will use individual SSL cert per domain and link both certs to (two or one) serverfarm.
policy-map multi-match popvip_01
class POP_VIP01
loadbalance vip inservice
loadbalance policy POP-POp3_PMT or popPMT1
loadbalance vip icmp-reply
ssl-proxy server GINPOP_SSLPROXY
connection advanced-options TCP_PARAM_Y
class POP3_VIP02
loadbalance policy POP-POp3_PMT or POPPMT2
ssl-proxy server GINPOP3_SSLPROXY
however,
if I can get one single certificate to process both pop and pop3 domains, that use the same VIP/port, and if this will work with ACE, i'm inclined to design using this alternative.
ie,
pop.mydomain.com = 10.10.10.1 995
pop3.mydomain.com = 10.10.10.1 995
Any suggestions would be appriciated.
Correct Answer by JamesLuther about 8 years 3 months ago
In order to achieve this then you will need to order a wildcard certifictae ie
*.mydomain.com
These certificates are more expensive and so you will probably find it cheaper to buy two certificates than one wildcard certificate.
Overall Rating: 5 (2 ratings)
Correct Answer
JamesLuther Mon, 03/30/2009 - 03:04
  • Silver, 250 points or more
*.mydomain.com
