Upgrade 6.1.3.3000-1 Failure
03/28/2009 18:45:33 | root: Upgrade 6.1.3.3000-1 Start
03/28/2009 19:15:14 | root: Upgrade 6.1.3.3000-1 Failure
03/28/2009 19:15:14 CCMInstall|(CAPTURE) installFull rc[1]|<LVL::Debug>
03/28/2009 19:15:14 CCMInstall|(CAPTURE) installdb Failure [-i] 1|<LVL::Debug>
03/28/2009 19:15:14 CCMInstall|(CAPTURE) Stop DBMS|<LVL::Debug>
03/28/2009 19:15:14 CCMInstall|(CAPTURE) su -c 'if [ -f /usr/local/cm/db/informix/local/ids.env ]; then source /usr/local/cm/db/informix/local/ids.env l2; fi ; onmode -yck' - informix|<LVL::Debug>
03/28/2009 19:15:14 CCMInstall|(CAPTURE) cm-dbl-install [1]|<LVL::Debug>
03/28/2009 19:15:14 CCMInstall|Internal Error, File:instMain.c:1403, Function: handlePhase(), Failed to exec command: "/partB/usr/local/bin/base_scripts/env.sh nice -n 19 /usr/sbin/chroot /partB /usr/local/cm/script/6.1.3.3000-1/cm-dbl-install L2 PostInstall 6.1.3.3000-1 6.1.3.1000-16 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt"|<LVL::Critical>
03/28/2009 19:15:14 appmanager.sh|CCMInstall --upgrade ERROR|<LVL::Error>
03/28/2009 19:15:14 upgrade_manager.sh|Applications upgrade failed|<LVL::Error>
Where to search for a problem...?
llozanos81 Wed, 05/06/2009 - 07:41
I have the exact same Issue, did you find any solution to this?
05/06/2009 11:20:26 CCMInstall|cmdExec: Command: /partB/usr/local/bin/base_scripts/env.sh nice -n 19 /usr/sbin/chroot /partB /usr/local/cm/script/6.1.3.3000-1/cm-dbl-install L2 PostInstall 6.1.3.3000-1 6.1.2.1000-13 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt -- failed with failure code 1|
05/06/2009 11:20:26 CCMInstall|(CAPTURE) installFull rc[1]|
05/06/2009 11:20:26 CCMInstall|(CAPTURE) installdb Failure [-i] 1|
05/06/2009 11:20:26 CCMInstall|(CAPTURE) Stop DBMS|
05/06/2009 11:20:26 CCMInstall|(CAPTURE) su -c 'if [ -f /usr/local/cm/db/informix/local/ids.env ]; then source /usr/local/cm/db/informix/local/ids.env l2; fi ; onmode -yck' - informix|
05/06/2009 11:20:26 CCMInstall|(CAPTURE) cm-dbl-install [1]|
05/06/2009 11:20:26 CCMInstall|Internal Error, File:instMain.c:1403, Function: handlePhase(), Failed to exec command: "/partB/usr/local/bin/base_scripts/env.sh nice -n 19 /usr/sbin/chroot /partB /usr/local/cm/script/6.1.3.3000-1/cm-dbl-install L2 PostInstall 6.1.3.3000-1 6.1.2.1000-13 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt"|
05/06/2009 11:20:26 appmanager.sh|CCMInstall --upgrade ERROR|
05/06/2009 11:20:26 upgrade_manager.sh|Applications upgrade failed|
AHMED Ali Sat, 07/11/2009 - 15:58
I'm facing the same issue with sub node, but pub upgraded without any issue:
07/12/2009 02:42:06 CCMInstall|Internal Error, File:instMain.c:1403, Function: handlePhase(), Failed to exec command: "/partB/usr/local/bin/base_scripts/env.sh nice -n 19 /usr/sbin/chroot /partB /usr/local/cm/script/6.1.3.3000-1/cm-dbl-install L2 PostInstall 6.1.3.3000-1 5.1.2.1000-11 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt"|
07/12/2009 02:42:06 appmanager.sh|CCMInstall --upgrade ERROR|
07/12/2009 02:42:06 upgrade_manager.sh|Applications upgrade failed|
07/12/2009 02:42:06 upgrade_install.sh|Cleaning up download...|
07/12/2009 02:42:06 upgrade_install.sh|Removing /common/download/cisco-ipt-k9-patch6.1.3.3000-1.*|
07/12/2009 02:42:06 upgrade_install.sh|Removing /common/download/6.1.3.3000-1|
07/12/2009 02:42:06 upgrade_install.sh|Cleaning up misc...|
07/12/2009 02:42:07 upgrade_install.sh|Dumping /usr disk usage to /usr/local/platform/conf/usr_du_out.txt|
07/12/2009 02:42:07 upgrade_install.sh|Cleaning up rpm_archive...|
07/12/2009 02:42:07 upgrade_install.sh|Removing /common/rpm-archive/6.1.3.3000-1|
07/12/2009 02:42:07 upgrade_install.sh|CSA Status = 0|
07/12/2009 02:42:07 upgrade_install.sh|/etc/init.d/ciscosec start|
07/12/2009 02:42:09 upgrade_install.sh|(CAPTURE) Starting ciscosec: [ OK ]|
07/12/2009 02:42:09 upgrade_install.sh|Stop IOWAIT monitor|
07/12/2009 02:42:09 upgrade_install.sh|1|
Any one solve this problem please help.
llozanos81 Mon, 07/13/2009 - 06:29
Hi, i fixed this installing the Right Locale Package the same that i has installed in the backup server.
philippe.cousineau Wed, 08/05/2009 - 06:00
I have this problem when I try to upgrade from 5.1.3-4000-4 to 7.0.2a, on the publisher.
Do you suggest something
thanks a lot !
mmendonca Mon, 05/02/2011 - 12:12
In preparation for migrating UCCX 5 to 8 I've been setting up an environment in the lab including a pub, sub, UCCX server and probably will end creating a Unity Connection server as well. In the process of creating the Pub I ran into this 'unable to exec' error when attempting an upgrade from 6.1.2 to 6.1.3b.  Reading the response that someone fixed it by installing the correct locale package I started poking around. After looking at the install logs long enough I realized that I had changed the hostname prior to doing the upgrade.  I changed the hostname back to what it was prior to the updrade fail then 6.1.3(b) installed without a hitch.  Just figured I'd post that, hopefully it will help or point someone in the direction they need to go to fix something.
mark
