7600-SIP-200 being shut down
Mar 30th, 2009
I have a 7600 that is shutting down the 7600-SIP-200. I have replaced the7600-SIP-200, but I still get the below errors when I do show commands:
LONPWGPR2#show diagnostic event
Diagnostic events (storage for 500 events, 19 events recorded)
Event Type (ET): I - Info, W - Warning, E - Error
Time Stamp ET [Card] Event Message
02/25 12:15:06.423 I [5] Diagnostics Passed
02/25 12:15:43.063 E [1] BusConnectivityTest Failed
02/25 12:15:43.075 E [1] Major Error Detected
02/25 12:16:32.743 I [6] Diagnostics Passed
02/25 12:16:48.339 I [3] Diagnostics Passed
02/25 12:16:50.007 E [1] BusConnectivityTest Failed
02/25 12:16:50.019 E [1] Major Error Detected
02/25 12:24:15.353 E [1] BusConnectivityTest Failed
02/25 12:24:15.365 E [1] Major Error Detected
02/25 12:25:08.817 E [1] BusConnectivityTest Failed
02/25 12:25:08.829 E [1] Major Error Detected
02/25 12:27:01.929 E [2] BusConnectivityTest Failed
02/25 12:27:01.941 E [2] Major Error Detected
02/25 12:27:55.285 E [2] BusConnectivityTest Failed
02/25 12:27:55.297 E [2] Major Error Detected
02/25 12:28:48.889 E [2] BusConnectivityTest Failed
02/25 12:28:48.901 E [2] Major Error Detected
02/25 12:29:42.644 E [2] BusConnectivityTest Failed
02/25 12:29:42.656 E [2] Major Error Detected
------------------ show module ------------------
Mod Ports Card Type Model Serial No.
1 0 4-subslot SPA Interface Processor-200 7600-SIP-200 JAE130736UW
3 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE JAF1242BDJB
5 2 Supervisor Engine 720 (Active) WS-SUP720-3BXL JAF1243BGDL
6 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE JAF1238BBPR
Does this mean that there is a bus failure and the chassis needs replacing ?
Mayamba
guolichuan Sun, 09/05/2010 - 10:17
CSCtg11421
Symptoms: The following issues are observed:
All egress traffic by SIP-400 is dropped.
Consecutive BusConnectivityTest failure for SIP-400.
When SIP-400 is hosting intelligent SPAs such as SPA-8XCHT1/E1, then this SPA gets into
OutSrvc state.
Conditions: The symptom is observed with a SIP-400 with egress LLQ shaping and with a high
volume of traffic to low speed stream.
Workaround 1: SIP-400 reload using the hw-module module X reset command (where X is the
module/SIP-400 number).
Workaround 2: Remove LLQ configuration.
Workaround 3: SIP-400 microcode reload (where X is the module/SIP-400 number):
attach X
enable
microcode reload np
SHOW DIAGNOSTIC RESULT MODULE NOTIFICATIONS (if any)
WARNING: The following port(s) on Switch  module 2 have failed the BusConnectivityTest
test.
This is a disruptive test and runs automatically during bootup and Health monitoring
test except for the Flex WAN and CIP400 modules where is only runs on bootup. This
test is available for WAN linecards.
This test failure usually indicates a problem with the connection between the linecard
And the supervisor module.
TRY THIS :
* Inspect the backplane connector on the module  to make sure it is not
  damaged. If there is no visual damage, try the module in another slot
  or a different chassis. Also, inspect for bent pins on the slot connector
  on the backplane. You may want to use a flashlight when you inspect the
  connector pins on the chassis backplane.
* If the problem continues to occur, turn on the debug diagnose error
  trace to further troubleshoot the problem and determine if this module
  needs to be replaced.
