Managing a DMZ on a Cat 2940 switch
Mar 30th, 2009
Just a little advice about the setup I am looking at. I have an edge router 2651XM with a WIC-ADSL card in. I have a PIX 501 and and a Catalyst 2940. Is it possible and a reasonable idea to host a DMZ using a a couple of dedicated ports on the switch? If so, would it be an idea to host it on a dedicated port based VLAN? I want to host a website on the DMZ and my current thoughts on my setup are:
PSTN -> WIC in 2651
2651 -> PIX external I/F using one router I/F
PIX -> Catalyst
Catalyst -> 2651 on the second router I/F for routing on the switch
Thanks in advvance
Pat
Yudong Wu Mon, 03/30/2009 - 22:27
  • Gold, 750 points or more
CAT2940 is a pure layer 2 device. Therefore, you can configure two vlans on it to make it as two virtual switches, for example, configuring all ports for DMZ in one vlan and the rest ports in the other vlan.
