Difference in WebVPN Peers count for same license
Mar 30th, 2009
We have two ASA at different locations. These were bought with same licensing, but when checked, they show different capabilities for WebVPN Peer support:
ASA-1 using asa804-23-k8.bin:
> WebVPN Peers : 2
ASA-2 using asa803-k8.bin:
> WebVPN Peers : 500
Thanx in advance for your quick response.
oabduo983 Mon, 03/30/2009 - 07:22
  • Bronze, 100 points or more
By default the ASA comes with 2 WebVPN License...
I believe you may have something like, somebody was trying to upgrade from 803 to 804, then he fall into the bug CSCsu41224, then he had to upgrade to 804-23 with formatting the flash, when he formats the flash he has to get the activation key once again...
you need to Contact Cisco to get it...
send an email to [email protected] with the serial number of ASA-1... they should send you the correct license to recover it...
please rate if this helps!
