03-30-2009 05:38 AM - edited 07-03-2021 05:23 PM
hello;
We configured 1300AP series as root-nonroot bridge mode.
We want to hide SSID on APs, but we couldnt find the correct command on AP console.
How can we do ?
Thanks.
Solved! Go to Solution.
03-30-2009 06:07 AM
Using the CLI, log in and issue the following commands:
config t
dot11 ssid SSID_NAME
no guest-mode
That should do it! Be sure to do it on both ends.
Jeff
03-30-2009 06:07 AM
config t
no guest-mode
Jeff
03-30-2009 06:09 AM
I've just found the commmand.
Thnak you so much.
03-30-2009 06:15 AM
Glad you found it, sorry I was late :)
