ACS- Export/Import v3.3-4.1
Mar 30th, 2009
I have a v3.3 ACS Appliance and plan to rebuild it as a 4.1 Windows App. Can I do a backup/restore or an import/export to transfer all data to the new system?
Or do I need to build the app as 3.3, do the transfer, then upgrade to v4 ??
Ivan Martinon Tue, 03/31/2009 - 11:28
You need to build the appliance with 3.3, then perform the needed upgrades to move it to 4.1, backups are platform dependent which means you cannot import a backup created on a 3.3 to a 4.1 version.
