Issue with Cisco 11501 Load Balancer
Mar 30th, 2009
As we have one load balancer Cisco CSS-11501 which is having IP address i.e.10.72.52.11 , which is balancing load between two servers AWNPTR01(10.72.8.28) and AWNPTR02(10.72.8.29). 10.72.52.11 is not accessible from any of our servers IP address is 10.72.8.28, 10.72.8.29 & 10.72.8.35.It means it is not accessible from 10.72.8.x segment but access from all other segments like 10.72.7.x,10.72.6.x etc. in the network.
Both the servers 10.72.8.28 and 29 are able to ping the load balancer & responding to load balancer 10.72.52.11 on port 5282.As per our security engg. We need to move the both above mentioned server to some other vlan then 10.72.8.0/24 to access LB ip.
Any suggestions are highly appreciated in this regard!!
mchin345 Fri, 04/03/2009 - 10:03
  • Silver, 250 points or more
I would suggest that you make a single content rule with just the IP address defined and then use Source IP / mask to maintain persistence.
