ASA 5520 with SSL VPN and telnet/ssh plugin
Mar 30th, 2009
Hi all, I tried to setup a clientless SSL VPN with a telnet/ssh plugin on a ASA 8.0.4.
I use the plugin from Cisco. All works fine but when I connect via a proxy the connection timed out and no connection via ssh/Telnet is possible. It seems to depends on if I use a proxy (in my browser) or not. I'm not so experienced in java but what can I do because I have to use a proxy to connect to the Internet. The error message is: "Reason: Connection timed out: connect" Could someone help me with this? Regards, Stefan
oabduo983 Mon, 03/30/2009 - 07:25
This is a JAVA issue, you may upgrade the JAVA from or use firefox browser which sometimes helps fixing these issues automatically...
please rate this post if it helps!
thanks and regards,
