cisco router 800 series
John Blakley Mon, 03/30/2009 - 08:07
  • Purple, 4500 points or more
You should be able to configure the address on interface BVI1.
HTH,
John
John Blakley Mon, 03/30/2009 - 08:17
You would need to console into the device with your console cable. You can use hyperterminal or putty to connect to the device.
HTH,
John
John Blakley Mon, 03/30/2009 - 11:43
The command for setting your ip address?
conf t
int bvi1
ip addr 10.10.10.1 255.255.255.0
Copy and paste the lines that are between and and paste them into your hyperterminal window.
