nat or no nat
Answered Question
Mar 30th, 2009
  • Purple, 4500 points or more
I have a diagram to help better explain what I'm wondering. I think I'll need to, but maybe not.
My ASA has a private address on the inside interface, and a public address on the outside. Will I need to nat if my device in front is natting for other traffic?
John
Correct Answer by JamesLuther about 8 years 4 months ago
The question would be, does the fatpipe device have routes to your internal network?
If it does then there is no need to NAT on the ASA and you can have all your NAT in one place. If it doesn't have your internal networks in it's routing table then you will need to NAT on the ASA.
Overall Rating: 5 (1 ratings)
Correct Answer
JamesLuther Mon, 03/30/2009 - 08:50
  • Silver, 250 points or more
John Blakley Mon, 03/30/2009 - 11:23
Thanks James! The Fatpipe doesn't have our internal networks set up. It just has an "internal gateway" of my ASA's public address. I'm converting from a Symantec firewall now, and I don't see where it's natting, but I've got nat enabled on the ASA.
Thanks again,
John
