track non reachability
Mar 30th, 2009
I want an ip route to be active only when a reachability is down, the opposite of a regular track reachability
Is there a wait to do that?
Thanks for help
jrlaroche Mon, 04/06/2009 - 06:30
Thanks, I looked at that one already, it is pretty closed to what I want except that I want route 2 to be active only when route 1 is unavailable.
JamesLuther Mon, 04/06/2009 - 06:46
  • Silver, 250 points or more
It sounds like you just need to use a floating static. ie if you have two static routes
ip route 192.168.1.1 255.255.255.0 10.1.1.1
ip route 192.168.1.1 255.255.255.0 10.1.1.2 250
The second route will only install into the RIB if the first route is unavailable (due to the higher admin distance).
jrlaroche Mon, 04/06/2009 - 07:09
I hade try that
ip route 192.168.1.1 255.255.255.0 10.1.1.1 track 123
Why I still want to track unreachability is because I have some traffic that can't go trough route 1 that activate route 2 (ISDN connection), but I want that traffic to pass only when route 1 is unreachable.
I know this is kind of special need but I'm surprise that there is now way to do the opposite of tracking the reachability.
