PIM ASSERT
Answered Question
Mar 30th, 2009
WAN WAN
R1 R2
--LAN-
When Pim asserts were sent over the LAN between R1 and R2. What metrics will be included? Only the WAN metric to the source or metric from the LAN interface to the source?
Correct Answer by Harold Ritter about 7 years 10 months ago
Yuhui,
Section 3.6 of RFC4601 gives explains the exact scenarios in which the assert mechanism is needed in a sparse mode context.
http://www.ietf.org/rfc/rfc4601.txt
Correct Answer by Giuseppe Larosa about 7 years 10 months ago
Hello Yuhui,
>> 1. pim assert only works with PIM DM.
The title of the RFC is:
Protocol Independent Multicast-Sparse Mode (PIM-SM): Protocol
Specification
I would suggest you a quick read to it
Hope to help
Giuseppe
Overall Rating: 5 (2 ratings)
yuhuiyao Mon, 03/30/2009 - 11:58
WAN WAN
R1 R2
--LAN-
yuhuiyao Mon, 03/30/2009 - 12:00
Seemed I can not put a good diagram here.
Here is the connection:
WAN---R1---LAN
WAN---R2---LAN
R1 and R2 are connected via LAN.
Giuseppe Larosa Mon, 03/30/2009 - 13:09
Hello Yuhui,
the unicast metric to reach the source and the AD, the unicast metric of the LAN segment should be not important.
The target of the pim assert is to understand who is the best router to take the role to forward multicast traffic into the lan segment
see
rfc2362
sec. 3.5.1
Do unicast routing table lookup on source address from data
packet, and send assert on interface "I" for source address in
data packet; include metric preference of routing protocol and
metric from routing table lookup.
http://www.ietf.org/rfc/rfc2362.txt?number=2362
Hope to help
Giuseppe
yuhuiyao Mon, 03/30/2009 - 13:16
Thanks. If unicast metric of the LAN is not considered, a downstream router may have RPF neighbor as router A while the router B is actually passing mcast traffic because it wins the pim assert over the wan but did not win over the lan from the downstream router's perspective.
Giuseppe Larosa Mon, 03/30/2009 - 13:54
Hello Yuhui,
your note is good.
I think the PIM assert is sent on the shared link to elect a forwarder.
Downstreams routers have faculty to direct their PIM join messages to their preferred upstream neighbor.
So we could say the assert is useful on final client vlans but PIM joins messages from downstream routers shape the tree.
see
1 Downstream routers will select the upstream router with the
smallest metric preference and metric as their RPF neighbor. If
two metrics are the same, the highest network layer address is
chosen to break the tie. This is important so that downstream
routers send subsequent Joins/Prunes (in SM) to the correct
neighbor. An Assert-timer is initiated when changing the RPF
neighbor to the Assert winner. When the timer expires, the
router resets its RPF neighbor according to its unicast routing
tables to capture network dynamics and router failures.
sec 3.5.2 Receiving Asserts
Hope to help
Giuseppe
yuhuiyao Mon, 03/30/2009 - 14:23
2. I think downstream routers do not care if the mcast traffic is coming from the rpf neighbor or not, as long as the mcast is from the right RPF interface.
3. there "might" be some issues with PIM prune message. If PIM prune message is mcasted to everyone over the LAN and everyone over the LAN will process it, ecerything should be fine. (I guess it is how it works with PIM prune).
However, if PIM prune works like PIM join, though mcast but dedicated to a specific RPF neighbor, problem happens:
PIM prune might be sent to the RPF neighbor (LAN RPF winner but WAN assert loser) who is not actual passing mcast traffic. The result will be PIM prune will not prune. (I guess this is NOT how PIM prune works).
Correct Answer
Giuseppe Larosa Mon, 03/30/2009 - 15:00
Hello Yuhui,
Specification
Hope to help
Giuseppe
yuhuiyao Mon, 03/30/2009 - 15:03
I think PIM SM does not need PIM assert. Correct me if I am wrong.
Yuhui
yuhuiyao Tue, 03/31/2009 - 05:33
Can you give me an example where PIM assert is used at sparse mode?
yuhuiyao Tue, 03/31/2009 - 14:40
Thanks for you help. Just one more question: who will be "Encoded-Unicast-Upstream Neighbor Address" in pim join? Will that be RPF neighbor's address?
