call disconnect after 60 minute
Mar 30th, 2009
when i make voip call from callmanager configured with a sip trunk connected to the service provider, the call disconnect at 60 minute how i can make it to 4 hours?
Nicholas Matthews Mon, 03/30/2009 - 12:43
  • Red, 2250 points or more
Your provider may be erroring out on the CUCM session refresh re-INVITE.
You can try increasing the value of the service parameter to see if you get different results:
SIP Session Expires Timer
-nick
Afragoso2009 Tue, 07/21/2009 - 08:10
Hi Nic
I having the same problem
In my case the call disconect after 15 minute , but on the router I have "min-se 1800 "
Does any thing to be done on the Call Manager ?
Brgds
Nicholas Matthews Tue, 07/21/2009 - 09:46
It sounds like you have a session refresh problem with the provider.
2 ways to fix this:
increase the timer extremely high
find out what part of the refresh is failing.
15 minutes points towards failure because 1800 = 30 minutes, and the refresh happens at half the session. You probably have a CUBE bug you're hitting in regards to re-invites, or do not have 'midcall-signalling passthru' configured, or something similar.
hth,
nick
