4215 Java error: When connecting from IPS event viewer
Answered Question
Hello-
I received a java error when trying to connect to my 4215 with Cisco IPS event viewer. It is as follows:
IOException in open Subscription(): java.security.cert.CertificateExpiredException: NotAfter: Sunday March 29
Is the web server running on 10.x.x.x:443? Please check the communication parameters of the device.
I can set the date on my pc back to last week and all works fine like b4. I have tried updating my java to the latest version and created a new certificate from the IPS.
Any help would greatly be appreciated:
Correct Answer by digisridhar about 8 years 1 month ago
The issue can be resolved by following the steps as below
1.Login to the sensor.
2.Run the tls generate-key command.
3.Make sure the certificate is generated.
4.Add the device again. It should work now.
REf: http://www.cisco.com/en/US/products/hw/vpndevc/ps4077/products_qanda_item09186a008025c533.shtml
Do rate if it helped.
Sridhar
Overall Rating: 4 (1 ratings)
