prepend aggregate ?
Mar 30th, 2009
Can anyone tell me if you can set up and aggregate route under BGP-let's say aggregate 192.168.65.0 255.255.255.0 summary-only and than do a route-map on BGP neighbour with as prefix-list matching 192.168.65.0 and setting a prepand for that ? Please let me know. so I guess my question is if you can prepend an aggregate
Matt qomat Tue, 03/31/2009 - 06:22
but as-set will only show AS numbers that route came from. I need to prepend that route: example having two sites sending same aggregated router and you want prepend one of that aggregate. Both sites are in the same AS# and advertising aggregate to the cloud. So aggregate is showing same AS# from both. Adding as-set will not add additional AS. I want to add same AS three times so spoke sites will see one preferred shorter path.Please help
Laurent Aubert Mon, 03/30/2009 - 20:20
  • Cisco Employee,
I made a quick test and it's working.
setting the AS prepend via the attribute-map is not supported.
Laurent.
Matt qomat Wed, 04/22/2009 - 06:11
Did you configure something similar ?
router bgp 65555
no synchronization
bgp log-neighbor-changes
aggregate-address 192.168.0.0 255.255.0.0 summary-only
aggregate-address 192.168.10.0 255.255.255.0
aggregate-address 192.168.20.0 255.255.255.0
timers bgp 10 30
redistribute static
neighbor 10.0.0.2 remote-as 64552
neighbor 10.0.0.2 route-map prepend out
neighbor 10.1.0.2 remote-as 64552
neighbor 10.1.0.2 route-map prepend out
no auto-summary
ip http server
ip forward-protocol nd
ip route 192.168.10.0 255.255.255.0 Null0
ip route 192.168.20.0 255.255.255.0 Null0
ip prefix-list agregat seq 5 permit 192.168.0.0/16
ip prefix-list agregat seq 10 permit 192.168.10.0/24
route-map prepend permit 10
match ip address prefix-list agreg
set as-path prepend 65555 65555
It looks like router is taking only aggregate 192.168.0.0/16 and appends a prepend, which is what I wanted. Can you confirm ?
Matt qomat Wed, 04/22/2009 - 13:31
other question.
So site sending aggregate of two routes will keep advertising the aggregate even when it looses one of those routes?
like 192.168.0.0/16 when 192.168.10.0/24 is lost it will keep sending an aggregate until second routes is gone, right ?Will it send aggreagte after both are gone though?
Laurent Aubert Wed, 04/22/2009 - 16:46
  • Cisco Employee,
Actually you don't need the following commands:
Because the routes you are redistributing are already /24 subnets (same as your aggregated addresses)
You need at least one more specific route in your BGP table for an aggregate to be valid and propagated. So if you remove one static route, your /16 will still be announced. If you removed both static routes, your aggregate will be withdrawn.
Laurent.
