Warning message
SMI routing protocols that converge rapidly
Mar 30th, 2009
HSRP - Does the Standard Multilayer Image provide a routing protocol that can converge as rapid or near rapid (10/20ms) as when using EIGRP and HSRP together...Basically, is the Enhanced Mutilayer Image the best choice for achieving the fastest fault tolerant recovery times?
glen.grant Mon, 03/30/2009 - 15:02
  • Purple, 4500 points or more
I believe standard only supports RIP,EIGRP stub and static routing . If you need ospf and standard eigrp then you need Enhanced.
