incoming calls from PBX to UC520 over Ti ISDN- PRI receive dial tone
Mar 30th, 2009
Need to intercept incoming calls from PBX through the T1 connection and provide
routing rules based on the incoming number. Right now incoming calls receive dial tone from UC520
which is the best way to accompligh this?
Marcos Hernandez Mon, 03/30/2009 - 15:12
  • Blue, 1500 points or more
Check out this quick article:
https://www.myciscocommunity.com/docs/DOC-5286
On the dial tone issue, make sure your POTS dial peers (mapped to the PRI), have the following command "direct-inward-dial". CCA should be doing this by default.
Marcos Hernandez
Technical Marketing Engineer
Cisco Systems, Inc.
JMadrugaADM Mon, 03/30/2009 - 15:20
Thanks Marcos, in my case I'm routing DIDs from my PBX to the UC520 this are 4 digit stations. I need to do digit translation here
for example and incoming station 3939 needs to ring on IP phone ext 702
Marcos Hernandez Mon, 03/30/2009 - 15:28
This should be easy to do with the CCA inbound call routing/DID rules. Or do you need the CLI equivalent? In that case, something like this would work (shown for 2 numbers):
voice translation-rule 10
rule 1 /3938/ /702/
voice translation-rule 11
rule 1 /3939/ /702/
voice translation-profile First_DID
translate called 10
voice translation-profile Second_DID
translate called 11
dial-peer voice 10 pots
translation-profile incoming First_DID
incoming called-number 3938
direct-inward-dial
dial-peer voice 11 pots
translation-profile incoming Second_DID
incoming called-number 3939
direct-inward-dial
Marcos
JMadrugaADM Tue, 03/31/2009 - 06:33
Hi Marcos, I try these settings and it didn't work. The calls from the PBX just receive dial tone.
under the dial peer do I have to assign a port in this case like 0/2/0:23?
Is it possible to change the dial plan on the uc520 to match the PBX extations?
Marcos Hernandez Tue, 03/31/2009 - 06:39
You are getting dial tone because there are other POTS dial-peers with similar config that do not have "direct-inward-dial" configured. It is a good idea to add the port, I omitted that (although it is not strictly necessary for inbound dial peer matching).
Make sure that the only POTS dial peers with "incoming called-number" and "direct-inward-dial" are the ones you created following my configuration. Let me know how that works.
Marcos
JMadrugaADM Tue, 03/31/2009 - 10:31
Hi Marcos, the problem was on the PBX side with the route pattern.
It is now working great.
thanks
jaime
