Can IPCC-E Script know if any agents are logged in but not ready?
Answered Question
Mar 30th, 2009
My customer needs to route the call one way if there are agents logged in but not ready, and another way if there are no agents logged in at all. Is there a way to script this in ICM 7.0?
Correct Answer by david.macias about 8 years 3 months ago
You have a couple of different options. Using an IF node and the following:
SkillGroup..Ready
or
SkillGroup..LoggedON
Check help for details on how the above work.
david
Overall Rating: 5 (2 ratings)
Correct Answer
david.macias Mon, 03/30/2009 - 18:29
  • Blue, 1500 points or more
SkillGroup..Ready
or
david
rneil Wed, 04/01/2009 - 17:23
Looks like that did it. Thanks very much
sebastiaanv Tue, 04/14/2009 - 23:07
A little sidenote on using SkillGroup..LoggedON; I was using an IF which produced good results in my lab. However, when I migrated the scripts to our production environment and started testing, the overflow I had created (no agents logged on) was never triggered.
Turned out we had some agents that would just shut down the PC instead of logging off as per the Cisco recommended way. They would remain logged on until they had logged on again, and logged off the proper way (ofcourse the Supervisor Desktop would show the number of logged in agents, but their names would not be listed under "agents", it took me an hour to notice the "2" in the Agents column in the Team Skill Statistics Display :) ).
As this also has consequences for reporting, I created a script that e-mails the supervisor which agents didn't log off properly.
--bas
