Call Handling on GateKeeper
Mar 30th, 2009
Hello everyone,
I have the following situation:
I have 2 CallManagers on the cluster and I am registering to the GK with an Inter Cluster Trunk Gatekeeper Controlled.
Is there anyway I can register each CallManger of the cluster to separate zones in the GK?
As far as I know, when I create the trunk, the CCM registers depending on the order for the Device Pool.
This is because I need to prioritize and load balance calls.
Example:
Allow 10 calls for CCM Subscriber, but if this one fails, send calls to the CCM publisher.
Thanks for your time.
