WS-C2950G-24-EI error message
astanislaus
Level 2
Level 2
Mar 30 14:11:44.325 aedt: %SPANTREE-7-RECV_1Q_NON_TRUNK: Received 802.1Q BPDU on non trunk GigabitEthernet0/1 VLAN1.
Sw20 Gi0/1 (the one logging the above message) is connecting to Sw12 Gi0/2 which does not log any message.
I have checked a million times Sw20 Gi0/1 and Sw12 Gi0/2 and bot are access ports.
In fact the config under these interfaces are as simple as follow:
Sw20:
interface GigabitEthernet0/1
speed nonegotiate
Sw12:
interface GigabitEthernet0/2
speed nonegotiate
Did show cdp neigbor to make sure that Sw20 Gi0/1 goes to Sw12 Gi0/2
sw20#show cdp nei
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone
Device ID Local Intrfce Holdtme Capability Platform Port ID
sw12 Gig 0/1 148 S I WS-C2950G- Gig 0/2
7 Replies 7
astanislaus
Level 2
Level 2
One more thing I would like to add is Sw20 Gi0/1 is logging a few ( not too many ) Input errors - CRC errors.
But I cannot see that causing:
on Sw20
Now showing show cdp neighbor from Sw12:
sw12#sh cdp neigh
sw20 Gig 0/2 144 S I WS-C2950G-Gig 0/1
Leo Laohoo
Logging too many CRCs on the Gig interface of a 2950G? Can you check/replace the cables your are using (fiber optic or Cat5/6). If errors are still incrementing, change the both modules.
Regarding the BPDU errors, how about changing both ports to DOT1Q trunking?
Explanation An SSTP BPDU that was not operationally a trunk has been received on the specified interface.
Recommended Action:
Verify that the configuration and operational state of the listed interface and that of the interface to which it is connected have the same mode (access or trunk).
If the mode is trunk, verify the same encapsulation (none, ISL or 802.1Q). Once these parameters are consistent, spanning tree will automatically unblock the interfaces as appropriate.
Sal
Please rate if it helps
jimmysands73_2
Level 5
Level 5
I got this once and on two productions sw's that were running great for about a year.....after ts'g it was a cableing issue (replaced cable and error went away).
I have seen the same errors in a production enviroment in the past and it was caused by a bad fiber patch cable.
Did you change the patch cables on this issue at hand?
Sal
Thanks guys. I was going to replace the cable for the CRC errors ( although very few ) but I never thought the cable would have caused the error message I saw in the logs. Will let you know.
