Http download slows down with IP Inspection enabled
Mar 31st, 2009
I have 2811 with Advanced Security IOS 12.4.23
Router is connected directly to internet. Users are translated with PAT to internet. When I enable ip inspection
(ip inspect name my-ios-fw tcp
ip inspect name my-ios-fw udp)
any file download from http slows down almost immediately till it reaches 20-30 bytes/s. If I remove inspection from users' interface I can download files in without any problem
can anybody help me?
hadbou Mon, 04/06/2009 - 07:54
  • Bronze, 100 points or more
You may try configuring the "timeout seconds" parameter.
timeout seconds (Optional) - To override the global TCP or User Datagram Protocol (UDP), or Internet Control Message Protocol (ICMP) idle timeouts for the specified protocol, specify the number of seconds for a different idle timeout.
This timeout overrides the global TCP, UDP, or ICMP timeouts but will not override the global Domain Name System (DNS) timeout.
