New to IDS 4235.
Answered Question
Mar 31st, 2009
hi,
can anybody tell me how to access the console of the IDS 4235.
My ids shows only
ttya login:
and I am unable to type anything on this prompt.
Correct Answer by marcabal about 7 years 10 months ago
You will need to download the ISO CD image file from cisco.com.
Then use a CD burner to create a Recovery CD from that ISO file.
Put the CD into your sensor and reboot.
It should reboot from the CD and load a new image on the sensor.
http://tools.cisco.com/support/downloads/go/ImageList.x?relVer=6.0%285%29E3&mdfid=277026258&sftType=Intrusion+Prevention+System+%28IPS%29+System+Software&optPlat=&nodecount=2&edesignator=null&modelName=Cisco+IDS+4235+Sensor&treeMdfId=278875311&treeName=Intrusion+Prevention+System+%28IPS%29&modifmdfid=null&imname=&hybrid=Y&imst=N&lr=Y
Overall Rating: 5 (1 ratings)
rhermes Wed, 04/01/2009 - 09:07
That doesn't sound too healthy. You may want to try re-imaging that 4235 with a boot CD. You should be able to find a 5.x .iso image in the downloads.
jvalin__s Wed, 04/01/2009 - 22:02
sorry folks now I am able to login to the IDS but it shows only
# prompt nothing else..
There is not prompt like the usual one
sensor#
Please help.
rhermes Thu, 04/02/2009 - 08:44
Maybe you are logged into the service account. Do you get any response to sensor CLI (sh int) or Linux type commands (ls, pwd)?
jvalin__s Mon, 04/06/2009 - 21:23
hi guys,
I cant run any cisco related commands on the IDS but I can run linux commands on it.
rhermes Tue, 04/07/2009 - 10:17
You are logged into the service account. If you have another login, exit and log back in with administrator rights. If you can't, then reimage your sensor.
jvalin__s Tue, 04/07/2009 - 20:55
well the tac case guys also says the same thing.
I cant understand if we cant type any cisco commands on it, how are we suppose to re-image.
I dont have any other login.
Correct Answer
marcabal Wed, 04/08/2009 - 06:54
