NetFlow
Mar 31st, 2009
Is it enought on Catalyst 4500 enable NetFlow Globally (of course IP routing is enabled from before) with command:
Switch# configure terminal
Switch(config)# ip route-cache flow
or
does it needs enable aggregation configuration
and
what is difference between:
. Autonomous System Configuration
*Destination Prefix Configuration
*Prefix Configuration
*Protocol Port Configuration
*Source Prefix Configuration
regards,
davor
drolemc Mon, 04/06/2009 - 13:35
  • Silver, 250 points or more
To enable NetFlow (ingress) accounting for traffic arriving on an interface, use the
ip route-cache flow command in interface configuration mode.
