CSS11500 - specifying which interface to send out snmp traps
Mar 31st, 2009
Can some one please explain how I can define which interface to use to send out snmp traps generated on my css. I understand how to set the source IP address in the traps generated by the CSS however I am struggling to get it to send them from the correct interface. In addition can the CSS physically send the traps from its management interface?
Many thanks
acharyr123 Tue, 03/31/2009 - 23:49
As a best practice we should use Loopback interface to send SNMP traps. If CSS supports (ideally it must support) create a Loopback interface & specify that in snmp: snmp-server trap-source Loopback0
CGI-Europe Wed, 04/01/2009 - 01:28
Thanks Giles, does it just pick the source interface at random or is there some logic behind the choice made. (ie lowest vlan number)Thanks
