Callback process chat script fail on NM-16AM modem
melatisariindah
I have problem for configuring callback from NM-16AM modem module that attached in router.
Below the configuration for the router :
aaa new-model
aaa authentication login default local group radius
aaa authentication ppp default local group radius
aaa authorization exec default local group radius
aaa authorization network default local group radius
aaa session-id common
ip cef
voice-card 0
no dspfarm
chat-script offhook "" "ATH1" OK
chat-script callback ABORT ERROR ABORT BUSY "" "ATZ" OK "AT" OK "ATDT \T" TIMEOUT 60 CONNECT \c
chat-script rtp ABORT ERROR ABORT BUSY "" "AT" OK "ATDT \T" TIMEOUT 45 CONNECT \c
username admin password 0 admin
username lili callback-dialstring "" password 0 lili
interface Group-Async1
ip unnumbered GigabitEthernet0/0
encapsulation ppp
ip tcp header-compression
async mode interactive
peer default ip address pool async
ppp callback accept
ppp authentication chap pap
group-range 1 1/15
ip local pool async 192.168.0.250 192.168.0.254
radius-server host 192.168.0.220 auth-port 1645 acct-port 1646
radius-server key cisco
line 1/0 1/14
line 1/15
session-timeout 20
exec-timeout 120 0
script modem-off-hook offhook
script callback callback
modem InOut
modem autoconfigure discovery
transport input all
autoselect during-login
autoselect ppp
callback forced-wait 5
flowcontrol hardware
I have 2 phone line that 1 one of them connected to router modem, 1 for my computer. From my computer, I can make successful dialin with/without radius server as an authentication server. But if I dialin with callback process, It stop until message "waiting callback" from my computer.
This is debug in the router :
*Mar 31 09:11:19.405: Modem 1/15 ACF: State: Init
*Mar 31 09:11:20.669: Modem 1/15 ACF: State: Idle
*Mar 31 09:11:21.029: Modem 1/15 ACF: Event: Hook state: Off Hook Dialing
*Mar 31 09:11:21.029: Modem 1/15 ACF: State: Dialing
*Mar 31 09:11:21.185: CHAT1/15: Asserting DTR
*Mar 31 09:11:21.185: Modem 1/15 ACF: CMD DTR set high
*Mar 31 09:11:21.237: Modem 1/15 ACF: Event: Hook state: On Hook
*Mar 31 09:11:21.237: Modem 1/15 ACF: Event: DISCONNECT
*Mar 31 09:11:21.237: Modem 1/15 ACF: State: Idle
*Mar 31 09:11:21.237: TTY1/15: dropping DTR, hanging up
*Mar 31 09:11:21.237: tty1/15: Modem: HANGUP->IDLE
*Mar 31 09:11:21.237: Modem 1/15 ACF: CMD DTR set low
*Mar 31 09:11:23.237: TTY1/15: restoring DTR
*Mar 31 09:11:23.237: Modem 1/15 ACF: CMD DTR set high
*Mar 31 09:11:23.237: Modem 1/15 ACF: State: Endcall
*Mar 31 09:11:23.373: Modem 1/15 ACF: Event: ENDCALL: No Previous Call
*Mar 31 09:11:23.373: Modem 1/15 ACF: State: Init
*Mar 31 09:11:24.737: Modem 1/15 ACF: State: Idle
%This command has no effect on this line; use modem AT commands instead
*Mar 31 09:11:26.185: TTY1/15 Callback process chat script fail status=Connection timed out; remote host not responding
*Mar 31 09:11:26.185: TTY1/15: Line reset by "Callback Process"
*Mar 31 09:11:26.185: TTY1/15: Modem: IDLE->HANGUP
*Mar 31 09:11:26.185: TTY1/15: no timer type 0 to destroy
*Mar 31 09:11:26.185: TTY1/15: no timer type 1 to destroy
*Mar 31 09:11:26.185: TTY1/15: no timer type 3 to destroy
*Mar 31 09:11:26.185: TTY1/15: no timer type 4 to destroy
*Mar 31 09:11:26.185: TTY1/15: destroy timer type 10
*Mar 31 09:11:26.185: TTY1/15: destroy timer type 2
*Mar 31 09:11:26.237: TTY1/15: dropping DTR, hanging up
*Mar 31 09:11:26.237: tty1/15: Modem: HANGUP->IDLE
*Mar 31 09:11:26.237: Modem 1/15 ACF: CMD DTR set low
*Mar 31 09:11:27.237: TTY1/15: restoring DTR
*Mar 31 09:11:27.237: Modem 1/15 ACF: CMD DTR set high
*Mar 31 09:11:27.237: Modem 1/15 ACF: State: Init
*Mar 31 09:11:28.501: Modem 1/15 ACF: State: Idle
*Mar 31 09:11:35.237: TTY1/15: autoconfigure probe started
Can anyone help me, what should I add or reconfigure?
Thx,
BR,
msi
mchin345
Level 6
Level 6
Designates a string whose presence in the input indicates that the chat script has failed.
Sets the time to wait for input, in seconds. The default is 5 seconds, and a timeout of 60 seconds is recommended for V.90 modems. If a modem reports BUSY when the number dialed is busy, you can indicate that you want the attempt stopped at this point by including ABORT BUSY in your chat script.
