asa dmz and nat
Answered Question
Mar 31st, 2009
All,
I'm setting up an ASA, and I have a question about nat translations.
If I have:
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
Will the above be sufficient to get internet access if I have 4 interfaces:
inside: 192.168.1.0
dmz1: 192.168.2.0
dmz2: 192.168.3.0
dmz3: 192.168.4.0
Or do I need to set up a pool for all of the dmz interfaces? I think the 1 global and 1 nat should work for all to go out as the interfaces address.
John
Correct Answer by acomiskey about 7 years 9 months ago
You would also need....
nat (dmz1) 1 0.0.0.0 0.0.0.0
nat (dmz2) 1 0.0.0.0 0.0.0.0
nat (dmz3) 1 0.0.0.0 0.0.0.0
Overall Rating: 5 (1 ratings)
Correct Answer
acomiskey Tue, 03/31/2009 - 07:24
