3560E-24PD-E Not comunicating via SNMP v2
Answered Question
Mar 31st, 2009
Upgraded 2 3550-24 with 2 3560E-24 migrated config over to new switches
and I am unable to communicate with them via snmp v2 with the RO string. I have tried
several programs including LMS 3.1. I have removed the strings and re-added them from known
good configs still nothing. I did have an ACL on the strings and removed it with no luck.
I started out with 12.2(46)SE and upgraded to 12.2(50)SE with no improvement.
Correct Answer by Joe Clarke about 7 years 10 months ago
The SNMP portion looks good. I did notice your logging configuration might be problematic. How were you verifying the debug output? From what I could tell, you would have to have been running it on a VTY with "term mon" enabled.
Overall Rating: 5 (1 ratings)
Joe Clarke Tue, 03/31/2009 - 08:30
Try running debug snmp packet to see if the SNMP requests are making it to the switch. It could be that udp/161 is blocked between your manager and this device.
nwc.navy.mil Tue, 03/31/2009 - 08:45
Hello Jclarke,
I have enabled debug snmp packet and nothing is showing up in the log. I know UDP/161 is not being blocked on the LMS server I have no issues talking with the other network devices via SNMP v2. Should I try debug SNMP receive?
Joe Clarke Tue, 03/31/2009 - 08:49
If debug snmp packet is not showing anything, then you are not receiving SNMP packets. It may be that the filter is beyond the LMS server, and just in the path to this device.
You could try a sniffer trace at each hop in the path to see where the packets are stopping.
nwc.navy.mil Tue, 03/31/2009 - 08:55
The LMS server is on the same vlan/subnet as all the switches it's just these 2 3560E-24's. any other ideas?
Joe Clarke Tue, 03/31/2009 - 09:03
Please post the show run from an effected switch. There was a bug in 12.2(46)SE where SNMP would not respond if you were using DHCP on the Fa0 port. However, that was fixed in 12.2(50)SE, and you would have still seen something under "debug snmp packet". Therefore, I suspect a possible configuration issue.
Correct Answer
Joe Clarke Tue, 03/31/2009 - 09:23
nwc.navy.mil Tue, 03/31/2009 - 09:27
Let me try it again using the term mon. any other suggestions? or captures wanted?
