CCM 6.1 Third Party Billin Server
Answered Question
Mar 31st, 2009
Hi, i'm running a CCM 6.1 version, my customer has a third party billing server, the server was created in the callmanager and using sftp the billing server is receiveing the cdr and cmr files. The billing server developer ask me if the ccm can generate only one file , always wiht the same name , and then his application can delete this file before the new file gest generated (always wih the same name). Is this possible?, Cisco default behavior is generating cdr and cmr with this format : tag_clusterId_nodeId_datetime_seqNumber , based on the CDR File Time Interval. Thank you.
Correct Answer by Jaime Valencia about 8 years 1 month ago
you can only modify the interval to try to set a huge file per day, but it's not recommended due to the high CPU it will cause. probably the server could crash, that's the reason it's configured to do the process continuously during the day.
the filename cannot be changed to something permanent, the script has that format for the file using variables
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Tue, 03/31/2009 - 08:26
  • Cisco Employee,
  • Hall of Fame,
    2011
java
