03-31-2009 09:35 AM - edited 03-06-2019 04:55 AM
Hi every body!
Say we have this set up r1s0---------dsu/csu------T1-----------------csu/dsu---r2
Dsu/csu say is using internal clock. what clock rate should be configured so that r1 can send data at 1.544 Mpbs.
To put it another way, How do we determine the clock rate for a port?
Thanks a lot!
Solved! Go to Solution.
03-31-2009 11:32 AM
Hello Sarah,
the relationship is 1 to 1 in this case: the clock rate has to be set to 1544000 to allow the router to use a full T1 speed.
Edit:
there is the other thread where Victor, Edison and Vuyan have provided useful answers with a lot of detailed information you can find a better answer there
Hope to help
Giuseppe
03-31-2009 11:49 AM
Sarah,
The clock rate command is used on DCE serial interfaces, not under internal CSU/DSUs.
Internal CSU/DSUs use the 'timeslot' concept:
http://www.cisco.com/en/US/docs/ios/interface/command/reference/ir_s2.html#wp1011734
If you purchased a T1, you will enable all timeslots in the CSU
service-module t1 timeslots 1-24, speed 64
HTH,
__
Edison.
03-31-2009 11:32 AM
Hello Sarah,
Edit:
Hope to help
Giuseppe
03-31-2009 12:01 PM
Thanks a lot Giuseppe and Edison !
03-31-2009 11:49 AM
Sarah,
HTH,
__
Edison.
03-31-2009 04:28 PM
Just one more question.
Please consider a frame relay network.
A router is connected to frame really network by s0. This router has point to point connection to other sides which are also connected to frame relay network.
Now does LMI messages are only exchanged on physical int i.e s0 or they are also exchanged on sub interfaces?
thanks a lot!
