keepalives
Mar 31st, 2009
Can anyone explain to me what are the keepalives for? Do keepalives work on layer 2 or are they used on layer 3 routing protocols like EIGRP and OSPF. I am asking because OSFP for example uses dead intervals so what would be the point of having keepalives?
bsudol79p Tue, 03/31/2009 - 12:07
OK, so if I disable the keepalives on both interfaces on the routers that will still keep the connection alive correct? And I can just let the OSFP handle the connection with Hello packets?
lamav Tue, 03/31/2009 - 12:13
  • Blue, 1500 points or more
Read the document. :-)
lamav Tue, 03/31/2009 - 11:58
OSPF uses keepalives to track the health of its neighbor.
If it does not receive keepalives for a certain time interval (dead interval), it declares the neighbor dead.
A Hello of 10 seconds and a dead interval of 30 seconds means that an OSPF neighbor will expect to receive a Hello every 10 seconds. If it doesnt receive any hellos after 30 seconds, it declares the neighbor dead.
http://www.cisco.com/en/US/docs/security/vpn5000/manager/reference/guide/ospf.html#wp1019855
