Cisco_Sonicwall - VPN policy's Destination Network (Phase 2) Mismatch
Mar 31st, 2009
Hello everybody,
I need your help with a VPN that's driving me crazy.
I have to establish a tunnel between a Cisco C837 and a SonicWALL PRO 4100.
- The Cisco router has a dynamic public IP.
- Cisco local network: 172.16.41.24/29
- The SW has a static public IP.
- SW local network: 172.16.40.0/26
Aggressive Mode Phase 1 completes OK, but in Phase 2 SonicWALL log says:
"IKE Responder: Peer's local network does not match VPN policy's Destination Network"
"VPN Policy: pruebasdhcp; Proposed network: 0.0.0.0/0.0.0.0"
As the SW works fine with many other VPNs (to other routers with dynamic or static public IPs) I think the problem is located in the Cisco ACLs (I've also been able to establish a VPN between these two devices... but in Main Mode with static IPs), because trying to establish connection is up to one or two code lines --though it fails at Phase 2--.
I'll put some code to explain the situation:
crypto isakmp policy 20
encr 3des
authentication pre-share
group 2
lifetime 28800
crypto isakmp peer address XXX.XXX.XXX.XXX
set aggressive-mode password XXX
set aggressive-mode client-endpoint user-fqdn XXX@XXX.XX
crypto ipsec security-association lifetime seconds 28800
crypto ipsec transform-set sonicwall esp-3des esp-sha-hmac
crypto map sonicwallmap 20 ipsec-isakmp
description Tunel
set peer XXX.XXX.XXX.XXX
set transform-set sonicwall
match address 120
interface Ethernet0
ip address 172.16.41.25 255.255.255.248
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
no ip mroute-cache
hold-queue 100 out
interface ATM0
no ip address
ip nat outside
no atm ilmi-keepalive
dsl operating-mode auto
pvc 8/32
pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
ip access-group ext_fw in
ip mtu 1404
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp chap hostname XXX
ppp chap password 7 XXX
ppp pap sent-username XXX
ppp ipcp dns request
ppp ipcp wins request
hold-queue 224 in
ip route 0.0.0.0 0.0.0.0 Dialer1
ip nat inside source list 120 interface Dialer1 overload
ip nat inside source route-map nonat interface Dialer1 overload
ip access-list extended ext_fw
deny icmp any any redirect
permit tcp any any established
permit udp any any gt 1023
permit udp any any eq isakmp
permit icmp any any
permit ahp any any
permit esp any any
access-list 100 deny ip 172.16.41.24 0.0.0.7 172.16.40.0 0.0.0.63
access-list 100 permit ip 172.16.41.24 0.0.0.7 any
access-list 120 permit ip 172.16.41.24 0.0.0.7 172.16.40.0 0.0.0.63
route-map nonat permit 10
match ip address 100
With the configuration shown above, SW doesn't know there's a router trying to establish a VPN connection.
It only starts negotiating if I add the line:
access-list 120 permit icmp any any
But it has the following consequences:
- Ping isn't allowed anymore from Cisco router.
- "show crypto ipsec sa" shows first tunnel as:
interface: Dialer1
Crypto map tag: sonicwallmap, local addr XXX.XXX.XXX.XXX
protected vrf: (none)
local ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/1/0)
remote ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/1/0)
current_peer XXX.XXX.XXX.XXX port 500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
But, if I remove that line (access-list 120 permit icmp any any), I can see:
local ident (addr/mask/prot/port): (172.16.41.24/255.255.255.248/0/0)
remote ident (addr/mask/prot/port): (172.16.40.0/255.255.255.192/0/0)
But nothing happens (neither phase 1 tries to start).
Overall Rating: 5 (1 ratings)
Ivan Martinon Tue, 03/31/2009 - 13:41
Hi, I wonder why do you force the router to start the vpn tunnel as aggressive mode. The router indeed has a dynamic ip address, but as far as the SW supports the establishment of tunnels with a dynamic ip addres you should not use aggressive mode. As well i would like to know why do you have the following NAT line:
This line is using the same acl that match address on the crypto statements so pretty much you are overloading the whole network to the dialer when going to the tunnel.. I would get rid of it.
themachine Mon, 04/06/2009 - 06:03
I got it!!!
Thanks for your advices, imartino. I removed some unnecesary lines and finally got it working in aggressive mode... obviously without the conflictive line:
that was making mismatch both ends.
So, basically it was well configured. The problem was located in the way of making negotiation start. I was pinging from the router and today I realized that traffic had to come from the very end, that is, the computer.
And it works.
Kevin Porter Tue, 04/28/2009 - 08:09
Hi. I am trying to get a Cisco 871 to VPN connect to a Sonicwall and we are failing Phase 1. The router is using DHCP on the WAN. The Sonicwall is static. The router will not start Agressive Mode, which appears to be a problem at the Sonicwall. Any thoughts on what to check on the Sonicwall and the router would be greatly appreciated...
Ivan Martinon Tue, 04/28/2009 - 08:45
Yes, does your router have configuration to connect to a static vpn or does it have configuration of an aggressive mode setup?
Kevin Porter Tue, 04/28/2009 - 09:14
I am connecting to the Sonicwall's Static IP. The router is set for DHCP. Since I don't have a static IP for the Router, I'm assuming that I cannot use Aggressive Mode, since the "crypto isakmp peer X.X.X.X" command is looking for my Routers static IP...
Ivan Martinon Tue, 04/28/2009 - 09:16
Good, what are the debugs you get when the router tries to connect for isakmp and ipsec?
Kevin Porter Tue, 04/28/2009 - 09:29
First question on my response...Should the initial design actually work (Sonicwall in Aggressive Mode and router with "standard" IPSEC config and using DHCP for the WAN)?
My Sonicwall rep says that the Cisco router will not run in Aggressive Mode unless there is a Static IP Assigned to the WAN and is referenced in the ISAKMP PEER to set aggressive mode....
Funny thing is that the Sonicwall will not run Main Mode unless a peer Address is entered into the configuration page...
My debugs look fine as the router is building the ISAKMP connection. The failure is at the Sonicwall that won't dynamically switch to Main Mode.
If we switch the Sonicwall to Main Mode, use the PAT address of my Firewall (which is where the router is getting sent to the internet and something that I can't do in production), and take out the Aggressive-mode stuff from the router, the Tunnel comes all the way up except for no receive decrypted packets...
Ivan Martinon Tue, 04/28/2009 - 09:31
Wrong, the router will work without having a static ip address assigned to the wan the config needed is dynamic to static vpn, your router should have a static crypto map configured and your SonicWall will only need to allocate this as a dynamic connection
Kevin Porter Tue, 04/28/2009 - 09:38
OK.
Here's my config, do you see anything wrong with it? If not, I don't think that I am getting good assistance on the Sonicwall...
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.97.1 192.168.97.200
ip dhcp excluded-address 192.168.197.1 192.168.197.200
ip dhcp pool DATA
network 192.168.97.0 255.255.255.0
default-router 192.168.97.1
dns-server 192.168.1.5 192.168.1.6
domain-name cvistl.com
ip dhcp pool VOICE
network 192.168.197.0 255.255.255.0
default-router 192.168.197.1
option 150 ip 192.168.101.5
ip domain name cvistl.com
crypto isakmp policy 10
encr 3des
group 2
crypto isakmp key Interior2009 address 63.252.122.130
crypto isakmp keepalive 10
crypto ipsec transform-set CVI_VPN_SET esp-3des esp-sha-hmac
crypto map CVI_VPN 10 ipsec-isakmp
set peer 63.252.122.130
set transform-set CVI_VPN_SET
match address 110
archive
log config
hidekeys
ip tcp synwait-time 10
class-map match-any VoIP-Control
match ip precedence 3
class-map match-any VoIP-RTP
match ip precedence 5
policy-map WAN-QOS-POLICY
class VoIP-RTP
priority percent 40
class VoIP-Control
bandwidth percent 25
class class-default
fair-queue
interface FastEthernet0
switchport voice vlan 2
spanning-tree portfast
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description WAN Interface
bandwidth 500
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1350
ip route-cache flow
duplex auto
speed auto
no cdp enable
crypto map CVI_VPN
service-policy output WAN-QOS-POLICY
interface Vlan1
description DATA VLAN
ip address 192.168.97.1 255.255.255.0
interface Vlan2
description VOICE VLAN
ip address 192.168.197.1 255.255.255.0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet4
no ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
access-list 23 permit 192.168.0.0 0.0.255.255
access-list 102 permit udp host 63.252.122.130 any eq 10000
access-list 102 permit udp host 63.252.122.130 any eq non500-isakmp
access-list 102 permit udp host 63.252.122.130 any eq isakmp
access-list 102 permit esp host 63.252.122.130 any
access-list 102 permit ahp host 63.252.122.130 any
access-list 102 permit icmp any any echo-reply
access-list 102 permit icmp any any time-exceeded
access-list 102 permit icmp any any unreachable
access-list 102 deny ip 10.0.0.0 0.255.255.255 any
access-list 102 deny ip 172.16.0.0 0.15.255.255 any
access-list 102 deny ip 192.168.0.0 0.0.255.255 any
access-list 102 deny ip 127.0.0.0 0.255.255.255 any
access-list 102 deny ip host 255.255.255.255 any
access-list 102 deny ip any any log
access-list 110 permit ip 192.168.97.0 0.0.0.255 any
access-list 110 permit ip 192.168.197.0 0.0.0.255 any
control-plane
line con 0
exec-timeout 60 0
logging synchronous
no modem enable
line aux 0
line vty 0 4
access-class 23 in
exec-timeout 60 0
logging synchronous
no login
scheduler max-task-time 5000
ntp server 192.168.101.2
end
GW-871-ROB_K-01#
Ivan Martinon Tue, 04/28/2009 - 09:40
Debugs from your router will be useful, however I can tell that your match address has any as the destination, are you certain the sonicwall has the same any as the source? Are you certain the sonicwall has the correct settings for both p1 and p2? What error message you get from the sonicwall?
Kevin Porter Tue, 04/28/2009 - 10:07
In the "Dynamic" mode, the Sonicwall won't complete phase 1 do to the failure in setting up as Aggressive mode.
According to the gent working on the Sonicwall end, there was no way to configure a "source network", but only a Destination Network...
Ivan Martinon Tue, 04/28/2009 - 10:22
In min experience I have always seen sonic wall working with Cisco... can you disable aggressive mode on your sonic wall? and make the appropriate changes to reflect that?
Kevin Porter Tue, 04/28/2009 - 11:15
We have switched the Sonicwall to Main Mode, set the IP to what my 871 hits the Internet with and Phase 1 and Phase 2 complete. We can't do this in production since the production site does not have any Static, Public IP's...
Ivan Martinon Tue, 04/28/2009 - 11:19
Set the SonicWall to main mode and leave the 800 to be dynamic, I doubt there is no option on the SW that will let you put the tunnel as dynamic, you know sometimes some people confuse the fact that it uses aggressive mode with the fact that it will accept dynamic tunnel.
Kevin Porter Tue, 04/28/2009 - 11:41
The SW guy said that to run in Main Mode, he had to build the Tunnels with a Peer IP Address and we won't have a "static" ip at the 871 end...
Alan Chin Tue, 04/28/2009 - 13:41
Kporter,
I understand your frustration. I ran into the same issue that you are having a few months ago and I was able to get my remote workers to connect between 871w and SonicWall 2040.
Forget about creating VPN policies on your SonicWall, it will not work with any of the modes since your remote 871 is using dynamic WAN IP. Try below.
SonicWall Settings.
Use the default GroupVPN policies and set to use IKE preshare secret.
Phase1- Group2, 3DES, SHA1, 28800.
Phase2- ESP, 3DES, SHA1
Turn off PFS
Unchecked all advanced settings
Enable your GroupVPN policy
871 Settings.
encr 3des
group 2
crypto isakmp key Interior2009 address 63.252.122.130 no-xauth
let me know how it goes. Good luck.
Kevin Porter Tue, 04/28/2009 - 14:31
Thanks much for your reply. I will try this out and will repost the results...
Kevin Porter Wed, 04/29/2009 - 13:55
No joy! I cannot confirm 100% that the SW is configured as you suggested since I am not allowed to touch it. Looks like Phase 1 is not completing now, since the router is doing a lot of "retransmitting phase 1 MM_KEY_EXCHANGE" messages...
Ivan Martinon Wed, 04/29/2009 - 14:01
Key exchange means the preshare key or the identity is wrong, can you check if you can enable this on the router Crypto isakmp identity address
Kevin Porter Wed, 04/29/2009 - 14:11
The ID Payload was sending the Address of the WAN port that is using DHCP. Does the SW need to know the Identity of the 871 Router? If so, I would think that using the Hostname would be preferred, since that would never change...
Ivan Martinon Wed, 04/29/2009 - 14:14
It is a dynamic ip address hence the SW should have a wildcard preshared key
