Eompls connectivity issue between Me-6524 and 7606-S
Mar 31st, 2009
my problem is one side vc is up and the other side was down when I configure EoMPLS the configuration like this
ME-6524
interface GigabitEthernet1/13
switchport
switchport access vlan 101
switchport mode trunk
end
interface Vlan101
no ip address
xconnect 10.1.1.3 101 encapsulation mpls
end
K24#show mpls ldp neighbor
Peer LDP Ident: 10.1.1.3:0; Local LDP Ident 10.1.1.5:0
TCP connection: 10.1.1.3.646 - 10.1.1.5.19798
State: Oper; Msgs sent/rcvd: 109/114; Downstream
Up time: 00:27:48
LDP discovery sources:
Targeted Hello 10.1.1.5 -> 10.1.1.3, active, passive
GigabitEthernet1/25, Src IP addr: 10.1.35.3
Addresses bound to peer LDP Ident:
10.1.1.3 30.1.78.113 10.1.13.3 10.1.23.3
10.1.39.3 10.1.37.3 10.1.36.3 10.1.34.3
10.1.35.3
K24#show mpls ldp bind 10.1.1.3 32
lib entry: 10.1.1.3/32, rev 126
local binding: label: 75
remote binding: lsr: 10.1.1.3:0, label: imp-null
remote binding: lsr: 10.1.1.4:0, label: 23
K24#show mpls for 10.1.1.3 32
Local Outgoing Prefix Bytes Label Outgoing Next Hop
Label Label or Tunnel Id Switched interface
75 Pop Label 10.1.1.3/32 0 Gi1/25 10.1.35.3
K24#
K24#show mpls l2 vc
Local intf Local circuit Dest address VC ID Status
Vl101 Eth VLAN 101 10.1.1.3 101 DOWN
K24#
C7609-S-1(ME6524 connected to ES 2/0/15,2/0/16)
l2 vfi VPLS101 manual
vpn id 101
neighbor 10.1.1.4 encapsulation mpls
neighbor 20.1.1.1 encapsulation mpls
neighbor 40.1.1.5 encapsulation mpls
neighbor 40.1.1.6 encapsulation mpls
neighbor 10.1.1.5 encapsulation mpls no-split-horizon
interface Vlan101
no ip address
xconnect vfi VPLS101
end
KPE1#show mpls l2 vc destination 10.1.1.5 detail
Local interface: VFI VPLS101 VFI up
MPLS VC type is VFI, interworking type is Ethernet
Destination address: 10.1.1.5, VC ID: 101, VC status: up
Output interface: Gi2/0/15, imposed label stack {80}
Preferred path: not configured
Default path: active
Next hop: 10.1.35.5
KPE1#show mpls for 10.1.1.5 32 detail
Label Label or VC or Tunnel Id Switched interface
107 Pop Label 10.1.1.5/32 0 Gi2/0/15 10.1.35.5
MAC/Encaps=14/14, MRU=1504, Label Stack{}
0019AA55670E001CB0CB99C08847
No output feature configured
KPE1#
VFI VPLS101 VFI 10.1.1.5 101 UP
the problem is On 6524, when I invoke the show mpls l2 vc 101 detail.
the next-hop marked " Next hop: Invalid ADDR"
Why?.. Why not up on ME6524
the mpls ldp bind ok, forwarding ok,
when I do show ip route on ME6524, It was ok.
Help me..
Giuseppe Larosa Tue, 03/31/2009 - 13:15
  • Hall of Fame,
    Founding Member
Hello Seungyeop,
first of all I would change config of port g1/13
int gi1/13
switchport mode access
so that it is clear you have a port in Vlan101 in STP forwarding state.
Hope to help
Giuseppe
syjeon Tue, 03/31/2009 - 15:25
I'd deleted switchport mode access,
and I made a trunk port in gi 1/13
but the symptom is same thing like before.
Do you have a another action plan?
Harold Ritter Tue, 03/31/2009 - 19:43
  • Cisco Employee,
Seungyeop,
Configuring the xconnect on an SVI interface enables local switching and requires additional hardware. On the 7609, the ES20 enables you to do that.
The solution would be to configure the xconnect under the physical interface on the ME6524.
kiwlee Wed, 04/01/2009 - 11:42
  • Cisco Employee,
Hi Ritter,
Thank you for your reply.
We are testing H-VPLS. On the testing, we met upper problem, When we change to ME3750 from ME6524, it looks fine. So, we assume it would be ME6524 issue. BTW,In 6524 datasheet on cisco web, ME6524 also can support MPLS VC Type 4. I am confusing what is correct. So I need helps experts.(looks like you :-)
Unfortunately, We should use MPLS VC type-4 on ME6524 with H-VPLS. :-(
CE-UPE(6524)-NPE(7606-S)-P(GSR)-P(GSR)-PE-NPE(7609)-UPE(6524)
Your help in this issue will be appreciated.
Kiwon,Lee
Advanced Services.
Harold Ritter Wed, 04/01/2009 - 12:41
  • Cisco Employee,
Kiwon,
You can use VC type 4 on the ME6524. You need to configure the xconnect statement under a dot1q subinterface as follow:
interface GigabitEthernet1/13.101
encapsulation dot1q 101
  • Cisco Employee,
Kiwon,
kiwlee Thu, 04/02/2009 - 11:05
  • Cisco Employee,
Hi Ritter,
It looks fine after change config. I assume that it is normal. It would be better for customer.
Thank you very much.
Kiwon.
